Home › Forums › Products › Stompboxes › more than 1 stompbox on H9 control: possible? › Reply To: more than 1 stompbox on H9 control: possible?
October 20, 2018 at 8:13 am
#150363
pinup57 wrote:
Hi, I have a TimeFactor and a PitchFactor, connected over USB via a iConnect4+ midi interface to a Windows PC. H9 recognises only 1 of the pedals at once. Each is recognised if the other is unplugged. FW is up to date and both are registered. Is that normal behaviour or is there something I missed?
Thanks
Dirk
I just checked using a simple usb hub and that works. So it might be a midi interface issue. H9 control always complains that it’ can’t open the midi port when I connect through the interface, but it still connects to the stompbox. a second later.
