Home › Forums › Products › Plug-Ins › SP2016 Reverb bypass problem Logic 9 › Reply To: SP2016 Reverb bypass problem Logic 9
#150437
tlongabaugh
    frywolny wrote:
    Hi Tom In both situations (bypass in plugin or Logic) the effect is the same. Also, the sound of the direct signal (mix fader down) has the same phasing problem as with bypass button. Ziggi
    Hey Ziggi-
    I just took a closer look at this – can you confirm that under Preferences -> Audio -> General -> Plug-in Latency, that Compensation is set to "All"? If it is set to "Off" or "Audio and Software Instrument Tracks", then you will hear phasing issues under the settings you describe, as SP2016 Reverb induces some latency, and uses Delay Compensation to offset this.
    -Tom
