Home Forums Products Stompboxes H9 smooth volume control Reply To: H9 smooth volume control
#150643
Alancarl
    bansta wrote:
    My BOSS FV500L volume pedal is connected to my Boss ES-8, which sends a MIDI CC (input volume) to the second, last in the chain, H9 (that is allways on). It works absolutely amazing, with any artifacts, but with a couple of positive side effects: At first I don’t have the volume pedal in the signal path, and second: I can use the pedal on a preset basis for different purposes (expression, for example) as well.
    That’s cool that you are getting useful results with this type of setup…
    However I was noticing the zipper noise when I was trying to change the H9’s input or output volume with midi cc’s or w it’s own expression pedal input.
    It’s subtle but noticeable in a quiet setting especially. Nonetheless I still love Eventide and the H9!
    Thanks
    Al
