Home Forums Products Stompboxes Compact MIDI pedal for H9? Reply To: Compact MIDI pedal for H9?
#150883
4_cuerdas
    bohan wrote:
    4_cuerdas wrote:
    Hello fellow H9-ers :-), Is it possible to activate/deactivate the repeat function in a delay patch with a midi switch pedal? If this is the case can somebody recommend me the smallest midi switch pedal that can help me achieve what I want? Another thing I want to do with the same midi pedal is to access the restart sequence button in a harpeggiator patch, is that possible? Can somebody point me in the right direction? Cheers!
    There are many options you can choose from. You don't even need a MIDI device to do this. You may get an aux switch to do what you want (something like this: https://store.eventideaudio.com/collections/accessories/products/ox-9 ). You can assign the Performance switch (aka Middle footswitch) to an aux switch to achieve the REPEAT and RESTART function in delay and Harpeggiator algorithms.
    If you do want a small MIDI controller, here I listed some I heard are good:
    http://www.freethetone.com/en/products/system/mc3.html
    https://www.disasterareaamps.com/shop/dmc-3xl-gen3
    http://www.one-control.com/gecko-mkiii-midi-switcher.html
    You would need to assign a MIDI CC message to the Performance switch (aka Middle footswitch). You can do this easily in H9 Control app in Pedal Settings -> MIDI Settings -> Assign MIDI CC messages to pedal functions
    Exactly! OSX9 it is!, I found that out a couple of hours ago by reading the manual :-). Thanks for your reply!
    Cheers 🙂
