Home Forums Products Stompboxes Problem Mounting Powermax Under Temple Audio Pedalboard Reply To: Problem Mounting Powermax Under Temple Audio Pedalboard
#150936
davebrubaker
    I appreciate your reply very much. The Duo 34 (which is what I bought) has one support rail installed. At first it looked like it might be possible, but there’s one fatal flaw.The Powermax has controls on the top surface. The mounting screws are on the back. So the top of the power supply would be facing up (out of view) if it were mounted to the support rail. I suppose I could have something made, but it would probably be expensive. I’ve already sunk close to $600 into the board and two power supplies, along with some other parts.
    I think I’m just going to mount the Powermaxs to the underside of the pedal as designed and forego the pedal mount plates. I’ll just velcro my pedals to the board. Not plan A, but it seems to make the most sense.
