Reply To: Pre/Post Routing Noise Issue
Home Forums Products Stompboxes Pre/Post Routing Noise Issue Reply To: Pre/Post Routing Noise Issue
#150945
ill_clinton
[/quote]
Then I guess it might be your external stompbox’s problem? What if you insert that stompbox into the Pre/Post loop? (Output 1 -> Stompbox -> Input 2)
[/quote]
Thank you for the response.
I initially thought it had something to do with the other boxes as well. I have tried what you suggested and when I insert any of them, (Output 1 > Stompbox > Input 2 > Output 2 > Amp) the noise is there. But if I go straight to the amp, (Output 1 > Stompbox >Amp) there is no noise.
I’ve swapped pedals, cables, power sources. I’m stumped.
