Home › Forums › Products › Stompboxes › Problem Mounting Powermax Under Temple Audio Pedalboard › Reply To: Problem Mounting Powermax Under Temple Audio Pedalboard
January 13, 2019 at 3:53 am
#150987
The nice folks at Temple Audio reached out to Cioks and they have a fix for this issue, Basically it’s a small screw with a male end and a female end. It acts as a spacer between the back of the Powermax and the bottom of the pedalboard. It’s only about a 1/4 inch of space, but apparently that’s enough for the mounting plates. Not sure what the part number is. The Cioks website is pretty confusing. If you have the same issue contact Temple Audio.
