Reply To: Harmonizer
Home Forums Products Stompboxes Harmonizer Reply To: Harmonizer
#151045
bohan
peaveyfan wrote:
Listen to Your Grace Is Enough by Chris Tonkin. The song is in A, they use a Capo on the 2nd fret and play it in a G pattern. I want to play it without a Capo. If you listen to the beginning guitar riff, to play without a capo, you would play an open G string on top of the riff played on the B. But again, that would put the song in G. Is there a way to just play 2 frets higher, on the B, and have the harmonizer resemble the G in A without harmonizing each note? I hope this makes sense. Thank you.
Well, H9 is not that smart to just shift one string and keep others unchanged. However, you can use PitchFlex or H910/949 algorithm to shift all strings a whole tone and just play the riff on the B as the way you played before with the capo. Don't forget to turn the MIX knob to 100 so there won't be any dry sound.
