Home › Forums › Products › Stompboxes › Mixing link questions › Reply To: Mixing link questions
January 24, 2019 at 4:17 pm
#151083
magnum wrote:
For live use in different venues each night should I set the set XLR out level to LINE on the bottom of the pedal?
Normally I think the FOH would run the mic into a preamp, should I ask him not to?
Yes, you should use LINE level XLR out. Just tell the sound guy that your output is balanced DI/LINE level. It can go to the FOH mixer directly.
