Home Forums Products Stompboxes Peak led always lit on H9 Reply To: Peak led always lit on H9
#151090
    It's not a known issue. You could try unplugging the input tand/or output to see if it goes off – if it does, it would suggest some kind of feedback loop.
    Otherwise, you could send it in to be repaired, but you may not consider it worth the effort.
