Home › Forums › Products › Stompboxes › Space Killdry off but no dry signal from Timefactor loop › Reply To: Space Killdry off but no dry signal from Timefactor loop
January 31, 2019 at 5:16 am
#151161
User error! I did not check the Routing in the Space and it was set to Wet/Dry instead of Normal. Hence, when the pedal was Active, Mix knob showed “Wet 0” and dry signal was muted.
