Home › Forums › Products › Stompboxes › TremoloPan Algorithm starting out of sync › Reply To: TremoloPan Algorithm starting out of sync
March 2, 2019 at 1:37 am
#151416
I could hook it up to Cubase… But I ~won’t~ until we really pin down your failure…
Is your tempo light in sync with your DAW… Yet the LFO is out of sync? With that preset you posted? Is that what you are saying?
Also, side note– it might help to broaden your troubleshooting algorithm a bit if you wanna to figure this out. Probably, 70% of the time(?) that people with complicated setups have weirdness… The problem is from the complicated setup.
