Home Forums Products Plug-Ins Equivocate Match Function – How Often Does it Update? Reply To: Equivocate Match Function – How Often Does it Update?
#151428
DGillespie
    The match EQ is meant to be static, not dynamic.  It does update the sliders as it learns on the fly, but it's integrating all the information it sees while MATCH EQ is on, and takes an average, so if you let it match for long enough you should see the sliders stop updating.
    Dan
    P.S. If you want to match Chorus and Verse separately, you can of course do this with two instances and automation.
