Home › Forums › Products › Stompboxes › H9 Dough Wimbish sound › Reply To: H9 Dough Wimbish sound
Agreed. You could probably use any of those algos. I heard 2 octaves up, though, from where he was on the fretboard. The shifted timbre & the initial glide screamed PitchFlex to me. As in ’embracing the glitch’, and using phrasing & vibrato to transform it into something expressive.
I don’t know how he engaged the effect. If it was by the FLEX / auxiliary switch, it’s probably a latching one. In that case, dial up the H-T GLISS for the initial glide. Expression pedal works (used for the preset above).
Using expression, the H-T GLISS, T-H GLISS, and SHAPE values don’t really matter. It’s a bright sound, so I left the LP FILTER at minimum. If you don’t have an expression pedal (just want that sound, without the glide), dial up the HotKnob to 100. Use ACTIVE / (BYPASS) to maintain your original tone.
All that said, I’ll bet the H910 / H949 algo would be very close, especially using one of the olders TYPEs.
