Home Forums Products Plug-Ins Blackhole crashes Cubase 10 and gets blacklisted Reply To: Blackhole crashes Cubase 10 and gets blacklisted
#151734
hcsametzki
    Hey Tom,
    thanks for your help. tried it exactly as you suggested. But it didn’t solve the problem. The first time I started Cubase after the procedure, I got a message that told me that Blackhole is blacklisted. When i tried to reactivate Blackhole in the pluginmanager, Cubase crashes without an error message. Same happens again with the UltraChannel. Again the 32bit-version of Blackhole seems to work fine in my old WaveLab and in Cubase using Jbridge… Also I’m using SlateDrums5 which also uses the software iLok-licenser (license on HD – not on an iLok) and there is no problem. Strange…
    Hans-Christian
