Home Forums Products Stompboxes Continual Pairing Problems with Mac OS X Reply To: Continual Pairing Problems with Mac OS X
#151773
gkellum wrote:
When I run into any problems pairing my H9, the first thing I do is turn Bluetooth off and then on again on the H9 by pressing the X, Y, and Z switches simulataneously (twice).  Oftentimes, I’m having trouble b/c I was using my H9 with another computer or iOS device, and doing this will break that connection.
If this doesn’t work, I’ll reset the H9’s system settings by turning the H9 off and then turning it on again with the HotKnob switch (the button in the upper left hand corner of the H9).  This almost always clears up whatever problem I’m having.
Will this same process work with the Pitchfactor? I was wondering if Bluetooth needed to be activated in the device in order to be found, which I’ve tried doing with my iPad, iPhone, and my iMac without any luck. Being able to use it with just the iPad (which I’ve installed the H9 app on) would be sufficient.
