Reply To: Continual Pairing Problems with Mac OS X
Home Forums Products Stompboxes Continual Pairing Problems with Mac OS X Reply To: Continual Pairing Problems with Mac OS X
#151775
bohan
solotasq wrote:
Will this same process work with the Pitchfactor? I was wondering if Bluetooth needed to be activated in the device in order to be found, which I've tried doing with my iPad, iPhone, and my iMac without any luck. Being able to use it with just the iPad (which I've installed the H9 app on) would be sufficient.
No. PitchFactor doesn't support Bluetooth connection. You would need to use an USB cable to connect to your PC/Mac/iOS devices to pair with the H9 Control.
