Home Forums Products Stompboxes Timefactor bypass via Midi – Can’t get it to toggle? Reply To: Timefactor bypass via Midi – Can’t get it to toggle?
#151815
bohan
    asopaque wrote:
    I've tried to get my Timefactor to toggle in and out of bypass mode via a single pedal switch, both with a CC command and also via PC command from a Behringer FCB1010.
    Both ways it doesn't seem to toggle. It only goes into bypass if I have the patch active. Any help?
    I suppose you mapped "BYP" to a CC message. There are three mappable bypass-related functions: BYPASS, ACTIVATE, and Toggle between Active and Bypass. I think you should map the third one to a CC. You may use H9 Control to set up your TimeFactor easily (See attached screenshot). Or you can set that in the setting menu on the unit, you should use TOG rather than BYP or ACT.
