Home Forums Products Stompboxes H9 core expression pedal programming Reply To: H9 core expression pedal programming
#152007
bohan
    raymondgsmith wrote:
     my issue is when programming the H9 for controlling specific parameters, somehow the expression pedal when all the way to toe down position puts the preset in bypass mode, then when in heel position, it becomes active again. how can I change this so that its active from toe to heel.
    See my attached screenshot. Make sure you choose "Expression Pedal" for this setting.
