Home Forums Products Plug-Ins H3000 Factory Bugs, Glitches, and Issues Reply To: H3000 Factory Bugs, Glitches, and Issues
#152245
tlongabaugh
    Hey, we got your email to support and will get back to you with more information there, as well as some things we'll need to investigate the issue.
    To get around the bouncing problem (in case you see this prior to the support response), can you try a realtime bounce (File->Bounce->Project or Selection, then select "Realtime" under Mode:).
