Home Forums Products Plug-Ins How to “Kill Dry” in SP 2016?? Reply To: How to “Kill Dry” in SP 2016??
#152294
pmcculloch
    Hi Armando, you should just be able to accomplish this on an Aux Channel by setting the mix to 100% wet.  If you find that the mix still sounds a bit too dry, try increasing the value of the position control, since this will adjust the balance between early reflections and late reverb.  Additionally, you might try increasing the predelay.
    Armando wrote:
    Hello! I thought the “KILL” button on the plugin would do this but it doesn’t do a true “Kill Dry” How is this accomplished so all the plugin passes is the “Wet” signal. I’ve got it on an Aux channel. Thanks!!
