Home › Forums › Products › Stompboxes › Solution for switching between PRE/POST and Stereo on the H9 › Reply To: Solution for switching between PRE/POST and Stereo on the H9
#152344
minor9
    mistercharlie wrote:
    One thing to note is that pre/post runs the signal through the AD/DA converters twice.
    Good point. Although if I had the pre side in a separate and deactivated loop on my switcher, the signal would in this case only run once through the converterrs – when going through the FX loop? On top of that, I could have the H9 in true bypass mode to remove it completely from the chain? Just trying to get my head around this.
