Home Forums Products Stompboxes (Problem) Harmadillo cant keep up the tempo Reply To: (Problem) Harmadillo cant keep up the tempo
#152642
bohan
    vyanezf wrote:
    Tried with different metronomes and noticed that this Algorithm goes progressively behind tempo, even if its plugged in via MIDI or Usb, so its useless for sidechain effects or so.(live settings) Tried every waveshape and still the same. It's only an issue with this Algorithm cause I change to a different tempo based effect ( any delay or so) and the clock's pitch perfect. Can you help or do something about it.?
    Is the ENV RATE on? That knob can change the rate as you play.
