Home Forums Products Plug-Ins H910 Harmonizer not showing in Reason 10 Reply To: H910 Harmonizer not showing in Reason 10
#152671
tlongabaugh
    fakearmusic wrote:
    Hey !
    Just bought the H910 plugin and tried to open it with Propellerhead's Reason 10, but it doesn't show up when I search for it in the Effects browser (neither in Instruments). I registered and authorized it, installed the 64bits VST version, rescanned my VSTs many times already, but still nothing.
    My Native Instruments plugins work fine with Reason… I heard that Reason only works with VST2, but the H910 is VST 2 right ?
    I'm running on PC, Windows 10.
    Cheers
    Sorry to hear about the trouble. H910 supports VST2 format, so it should work.
    Can you confirm that you have the install paths for the H910 64-bit VST2 set in Reason? By default, it is: C:Program FilesCommon FilesSteinbergVST2. Of course, if you changed the install path when installing H910, you'll need to select the appropriate path.
    -Tom
