Home › Forums › Products › Stompboxes › Eventide Rose – Modulation Modes › Reply To: Eventide Rose – Modulation Modes
Much appreciated for your resnponse.
Those videos are really ace by the way. Short, concise and right to the point!
So far, I understand:
– The LFO modulates only the PITCH of the delay line
– When Rate is set to minimum (counterclockwise), the Rose enters ‘Envelope Off’ mode allowing the Depth Control to act as a simple detuner
– When Rate is set to maximum (fully clockwise), the Depth Control allows to sweep the delay to generate pitch fluctuations
However, I can’t find a video where you explain all the different relationships available between the Rate and Depth Knobs to generate different effects depending on each of the five modulation sources available??
Could you explain this further?
Show More...I just find the effects generated quite unpredictable so far..
Thanks
