Home Forums Products Stompboxes H9 Option for Banks Using Aux Switch Reply To: H9 Option for Banks Using Aux Switch
#153101
bohan
    You should be able to set up your Fractal MFC101 or Midi Moose in a way that certain banks and presets send certain PC numbers, which can recall presets on H9 accordingly. Then what you need to do is only to put those algorithms/presets in your H9 in an order as you wish.
