H9 Option for Banks Using Aux Switch
Home Forums Products Stompboxes H9 Option for Banks Using Aux Switch
    • #115589
      bnjiman
        Hi Folks,
        I’ve been loving my H9 Max for the last few years, and before that my Space.
        In terms of control, I’ve had a few midi based units all the way up to a Fractal MFC101 with 17 buttons arranged into 4 banks = 51 presets.
        I’m thinking that was overkill and maybe an old Midi Moose could work (5 butttons with 2 bank up/down switches).
        I’ve recently come across the following approach which uses three buttons very neatly.
        Could this be implemented and mapped against a three button footswitch
        Bank size: User Definable
        Number of banks: User Definable
        Aux1 – Up Bank
        Aux2 – Down Bank
        Aux 3 – Increase Preset within Bank
        This would leave two switches on the H9 for activate etc.
        A possible implementation would be
        Bank Size: 5
        Presets per Bank: 2
        This would give the user 10 presets at maxiumum of three presses away
        Personally I could scale back to five main effects (Reverb1, Reverb2, Mod, Delay, Delay2)
        with the 5 banks (Spring, Spring Trem, Room, Plate, Chorus, Univibe, Slap Delay, Digital Delay, Vintage Delay, Spacetime)
        Hope this could be a useful feature !!
        Cheers
        Ben
      • #153101
        bohan
          You should be able to set up your Fractal MFC101 or Midi Moose in a way that certain banks and presets send certain PC numbers, which can recall presets on H9 accordingly. Then what you need to do is only to put those algorithms/presets in your H9 in an order as you wish.
        • #153109
          bnjiman
            Thanks for the reply. Yes this is possible however I don’t have the controllers at present. Hoping similar functionality could be achieved using a three way aux switch if the h9 could be programmed to support preset grouping.
            Cheers
            Ben
