Reply To: TriceraChorus Issues/Bug Reporting Thread
Home Forums Beta Boards H9 Beta Testers Algorithm Beta Testers Tricerachorus Beta Forum TriceraChorus Issues/Bug Reporting Thread Reply To: TriceraChorus Issues/Bug Reporting Thread
#153336
camn
BUGS?
1- If I assign a parameter to the XYZ…. then I use the HotKnob to change it.. the changes are not reflected in real time to the H9 control. Vice Versa works.. if I dial a parameter in H9 Control while the H9 has that parameter selected… it is reflected on the H9
2- If I assign a change to the HOTSWITCH.. and then I click my AUX switch that fires HOTSWITCH.. it does nothing. If I use the Software Hotswitch it works.
(both confirmed working in other algos)
versions 5.8.4(1) and 3.6.4
