Home Forums Products Stompboxes The Rose and midi connexion Reply To: The Rose and midi connexion
#153733
tsternfeld
    jumikael wrote:
    These cables work with Empress pedals so I thought it would be ok with the Rose.
    https://empresseffects.com/products/midi-to-1-4-cables
    What is happening in these little MIDI boxes that these adapters can't do ?
    Short answer: Opto-isolation and conversion to a voltage signal.
    I've bought a few of those cables to confirm if they work.   We usually require one of the boxes because DIN MIDI is specified as current-mode, designed to light an LED in an opto-isolator.  It is less complex electronically to share the jack between aux switches, expression pedal and a MIDI option if we can receive it as a voltage signal.  Of course, in the year since we released the Rose, things have transitioned to using adapter cables like the one mentioned.
