Home Forums Products Stompboxes Controlling timefactor and mod factor at the same time Reply To: Controlling timefactor and mod factor at the same time
#153796
bohan
    marcorocks wrote:
    Hi! New to midi and using these pedals so I apologize if this has been asked. I would like the timefactor to control the modfactor as explained here: https://youtu.be/rYpYXTtQ9DQ I got the tap tempo to work using the time factor as the main one, but changing patches is not working. The timefactor is set to transmit on. Is there anything I need to do on the modfactor? Also, if I use an aux switch with the timefactor, will that transmit to the modfactor as well?
    You would need to toggle on the Program Transmit on the TimeFactor.
    Yes. You can map your aux switch to some MIDI CC messages, and then assign those messages to your ModFactor's functions.
