Home Forums Products Stompboxes Controlling timefactor and mod factor at the same time Reply To: Controlling timefactor and mod factor at the same time
#153811
bohan
    marcorocks wrote:
    Those two are on but it’s still not sending over. I think the pgm xmt is on which is how I think the midi signal is being synced between the two. I’ll read the guide tonight and see if I can manually map it. I was thinking it would be as simple as the video made it seem 🙁
    The PGM.XMT has nothing to do with the Clock. If the PGM.XMT is on, the pedal will transmit the program change messages on the XMT.CH, which needs to match the ModFactor's RCV.CH. You might also need to check the XMT.MAP on the TimeFactor and the RCV.MAP on the ModFactor. By default, it maps MIDI Program Change 0-99 to the Preset 1-100. So if it hasn't been changed before, you don't have to change this one.
