Home Forums Products Stompboxes Controlling timefactor and mod factor at the same time Reply To: Controlling timefactor and mod factor at the same time
#153812
marcorocks
    bohan wrote:
    Does the MIDI channel match?
    Which one?
    Midi clock is working for tempo sync.
    Bypass and bank commands are not syncing. I have program transmit set to on for the master pedal.
    The main pedal has a transmit channel of 1 and the slave pedal is set to Omni. I tried mapping it to 1 and that didn’t fix it either.
    I also tried (tried) mapping the aux switch to a midi CC to send the control that way, but I was unsuccessful.
    I even reset both pedals to try again.
