Home › Forums › Products › Stompboxes › Can the H9 sum the two Mono inputs before effecting them? › Reply To: Can the H9 sum the two Mono inputs before effecting them?
#153978
bohan
    FrankvonWelt wrote:
    Hi folks, I use my H9 max with synthesizers. In a live situation I have two Mono synths i would like to run thru the H9. And I would love to just hook up both to the H9 before sending the stereo out to a mixer. Is there a way to mix the 2 Mono to one stereo signal pre FX ? I already saw similar questions here. But no real solution. And the routing options in the general settings seem not to be able to do this. Thank you. Frank
    If you just want to sum the two mono inputs, you would need a mixer or something similar. You can also plug 2 synths into the input 1 & 2 jacks of the H9. But in this case the effect applied to both inputs might be different. For example, if the Delay Mix or Pitch Mix is at A10+B10, the Delay/Pitch A will affect the input 1, and the Delay/Pitch B will affect the input 2
