Home Forums Products Stompboxes Can the H9 sum the two Mono inputs before effecting them? Reply To: Can the H9 sum the two Mono inputs before effecting them?
#153979
FrankvonWelt
    Mh yes Plugin both in will not be the Same .. at the end Synth 1 will be on the left only. Synth 2 on the right only … and it depends on the the defect if some material from synth 1‘s wet Signal will be heated on the other side ..
    i know an external mixer would do the job but I don’t wanna carry 2 mixers and avoid extra gear just for such a „tiny“ purpose .. maybe Eventide will add this to a future firmware ..
