Home › Forums › Products › Stompboxes › switching presets with a blueboard and H3000 Native › Reply To: switching presets with a blueboard and H3000 Native
Hi-
I can't speak much to the iRig blueboard's functionality (beyond knowing it is a MIDI controller), but I believe this is achievable.
Instead of presets, which are not controllable via a parameter or MIDI, you should use the Snapshots section. Each "Snapshot" is effectively a preset (see the H3000 Factory Native User Guide for more details). Then, in Ableton Live, expose the Snahpshot parameter (using "Configure" in the effect rack). At that point, you should be able to use Ableton Live's MIDI-mapping functionality to map your iRig to the Snaphsot paramter, to step through Snapshots.
Hope that helps!
