Reply To: Controlling expression via midi
Home Forums Products Stompboxes Controlling expression via midi Reply To: Controlling expression via midi
#154321
ollenys
So, ni success yet…
Just checking that I understand correctly: The H9 requiers that I set a specifik midi Transmit Chanel. That means that I can’t use it to controle two units with different midi channels? I would prefer to set the midi transmit channel to omni while the Volante and BigSky ignors exp-midi as long as i don’t specificly program the preset to respond.
In the XMT CC dialog I can chose the destination CC# from 1-99, wich is unfortunate when the Volante seemes to be set to receiver on CC# 100.
Is this correct or do I missunderstand something?
Appreciate your help!
/Olle
