Home › Forums › Products › Stompboxes › Pitch factor: any horn players here? › Reply To: Pitch factor: any horn players here?
April 13, 2020 at 6:57 pm
#154587
John Baylies wrote:
With the pedal, I just have one EQ after the pedal, To dip 120hz & 1200hz, and to cut above 7khz.
With the H9K I like to have EQs pre and post pitchfactor (set to killdry), with another EQ on a separate channel for my dry sound.
I should add that the mic goes into a Voco Loco preamp/effects loop, which has an EQ, then out to the chain. The VL EQs are limited, just a bass and a treble knob for both in and out, but better than nothing. Yes, I too use Killdry, as it is redundant in this system. I agree that the synth setting is an improvement over the guitar setting.
