Reply To: Blackhole bug : in and out level
Home Forums Products Plug-Ins Blackhole bug : in and out level Reply To: Blackhole bug : in and out level
#154662
tlongabaugh
Hi, if you are using AU, this is a known issue with Blackhole AU and Ableton 9. The issue was fixed in Ableton 10. You can use the VST version of Blackhole, which should work properly.
