Home Forums Products Stompboxes H9 Daisy Chain Power Rail Hum Reply To: H9 Daisy Chain Power Rail Hum
#154775
tsternfeld
    If the hum changes tone as you add and remove pedals that aren't the H9, then it probably is the power supply causing problems rather than the H9.  The H9 might just be the largest current draw that pushes the power supply past its capabilities.
