Home › Forums › Products › Rackmount › H8000fw CAN’T SYNC via AES/EBU › Reply To: H8000fw CAN’T SYNC via AES/EBU
May 17, 2020 at 2:06 pm
#154892
Syncing to the FireWire is often unsuccessful, as the FireWire canj be very jittery.
Strongly suggest you either set the H8000 is clock master running on internal sync, or use a Wordclok as clock master and sync everything else to it.
Again, you cannot use AES 1/2 as the clock source.
