Reply To: Triad centered voicing on the H9
Home Forums Products Stompboxes Triad centered voicing on the H9 Reply To: Triad centered voicing on the H9
#154942
John Baylies
I own the PitchFactor, not the H9, but I think they work similarly, in that the closest you could get to the effect you're describing is to use an expression pedal or button to change the interval manually when you're playing a root or a 5th.
