Reply To: Volume Boost Feature For HotSwitch
Home Forums Products Stompboxes Volume Boost Feature For HotSwitch Reply To: Volume Boost Feature For HotSwitch
#154947
Sicak
Thanks for the reply guys.
Yeah I’m guessing it must be impossible to map the output sliders to each algo or the champs at Eventide would have done this by now.
Still an amazing pedal never the less…
apalazzolo wrote:
I have looked all over for this.
The “trim” parameter in EQCompressor will do this.  So will the “output” parameter in MangledVerb (this can be used as a boost/overdrive if you turn off the reverb portion.  I believe Ultratap (which has a great delay) could easily be modified by Eventide to do this.  I have asked Eventide to consider it but they have not responded one way or the other.
People have asked Eventide to modify the “output” slider for every algo (on the right of the Control screen) to do this but it is apparently not possible.
Good luck!
