Home Forums Products Stompboxes H9 Algorithms & Presets suddenly disappeared Reply To: H9 Algorithms & Presets suddenly disappeared
#155065
cycledelia
    with the GE300 I only use send/return loop, but no MIDI. The mentioned presets also do not work when I just use the H9 as a standalone pedal. Which is strange because it used to work without any problems a few days ago. And now I’m just wondering how I could fix it.
    brock wrote:
    cycledelia wrote:
    I already tried the restore purchases in H9 Control (“sync algorithms on H9 with server”)
    H9 is connected to a Mooer GE300, and that worked without any problems until yesterday.
    otherwise no MIDI HW
    Reason I asked … CC#0 is the default (as I recall) for Input Volume in the H9.  And it appears that the Mooer GE300 uses that CC# for MIDI Bank Select; sending values of 0-1.  Which would mean next to no volume in the H9, if that were being sent / received.
