Home Forums Products Stompboxes H9 Algorithms & Presets suddenly disappeared Reply To: H9 Algorithms & Presets suddenly disappeared
#155068
cycledelia
    could not install FW via Direct Updater since H9 already has 5.8.5(1) installed. So I did six complete full factory resets and now it seems to work again. At least the listed presets act like normal. Hopefully it will remain like that.
    Strange things…
    but thanks again for your help!
    bohan wrote:
    cycledelia wrote:
    with the GE300 I only use send/return loop, but no MIDI. The mentioned presets also do not work when I just use the H9 as a standalone pedal. Which is strange because it used to work without any problems a few days ago. And now I’m just wondering how I could fix it.
    Have you tried reinstalling the latest firmware using the Direct Updater? You should also do a full factory reset after that (powering up with black encoder and right footswitch pressed and held)
