Home Forums Products Plug-Ins How to set up MIDI control for plugins in Logic Pro Reply To: How to set up MIDI control for plugins in Logic Pro
#155070
tlongabaugh
    Hi-
    MIDI control of audio effect plug-ins in Logic is a bit confusing.
    You need to create a new instrument track, and select the plugin as the instrument (it wll be listed under AU MIDI-Controlled Effects->Eventide->Plugin Name). Then, select the track with the audio you want to process in the Sidechain menu in the top right of the plug-in window. Now, if you have the instrument track selected, you should be able to play/record MIDI notes affecting the source audio.
    -Tom
