Home › Forums › Products › Stompboxes › Timefactor random crackly noises › Reply To: Timefactor random crackly noises
June 11, 2020 at 9:23 pm
#155115
alstrs wrote:
I need to amend this previous statement. The noise is coming through both wet and dry amps, and also when I'm using only one amp on both wet and dry signal. Again, only when the effect is on or in DSP/DSP+F bypass mode; it goes away when relay bypass is engaged.
OK. But if you just connect in mono (guitar -> input 1 -> output 1 -> amp), the noise is gone?
