Home › Forums › Products › Stompboxes › Getting that Space Echo Twist effect › Reply To: Getting that Space Echo Twist effect
June 22, 2020 at 8:17 pm
#155201
Maybe open the filter up to add some high end and bring the mix down slightly when making the feedback increase and time decrease. You might also try removing wow, flutter, and saturation. Or maybe you need to add saturation. Get it “twisting” and start tweaking those things though and see if anything helps.
