Home Forums Products Stompboxes H9 with 5 footswitches Reply To: H9 with 5 footswitches
#155510
bohan
    flat5 wrote:
    Thanks! Five assignable switches is great. What position for the Barn3 switch?
    The 2 switches on the pedal are not assignable. The left one can only bypass/active, the right one can either increment/decrement presets or tap tempo.
    3 aux switches are assignable, you can set the function mappings for Tip, Ring, Ring/Tip easily in H9 Control. See OX9's manual for more details of which switch is which:
    https://static1.squarespace.com/static/539f0880e4b0e0318ea3192f/t/5940029fb8a79bde2d979ab5/1497367242457/OX9-Manual-2017.pdf
