Home › Forums › Products › Stompboxes › Strange MIDI problem with H9 (see description) › Reply To: Strange MIDI problem with H9 (see description)
#155716
funkyfoe1
    Yeah, so I re-initialized it… same thing.
    What’s really strange is that the MIDI works with certain things connected and doesn’t with others.
    For example if my signal chain is-  Guitar>Tumnus> Phase 90 > H9 ……………..it will respond to MIDI
    If my signal chain has a second  H9 in the chain, it will not respond   ( Guitar>H9core>H9max) = H9max does not respond.
    BTW, I have the H9core set to “Thru”. But that does not matter, because as soon as I unplug any cable plugged in to it, the MIDI works fine.
    Also, if I put it in an effects loop ( which is how I want to run it)  it will not respond.
