Home Forums Products Stompboxes H9 doesn’t work, all lights are flickering, no reset possible Reply To: H9 doesn’t work, all lights are flickering, no reset possible
#155728
    mjahoger wrote:
    OK. The ribben cable was indeed loose on the top PCB (the one with the switches and lights). I managed to fit it back tightly, but when I turned over the case, 2 washers and metal tubes came off. I have no idea where these should be put back. Can you help me with this? Please find attached a picture.
    I spoke to the people who know how H9s are built. Apparently these are part of the fittings for the lens (red plastic part over display).
    They said "They go (washer, then sleeve) on the bosses closest to either end of the lens."
